Programatically deploy library with secuty settings
Hi
I need to programatically deploy a library that contains shared variables. I have shared variables with security configurations. When i do the manual deploy allways works fine.
But when i try to do the programatically deploy (with deploy library.vi [DSC] or application library:deploy library method) the variable "lose" the security configurations.
What i need to do to deploy the variable with the security settings??
(4,748 Views)
more issues...
if i create an installer, on the computer without labview the shared variables with security settings are not deployed at all.
only the variables without security configurations are deploied.
(4,737 Views)
Hello Idilio,
When you want to programmatically deploy a library with an installer you cannot used the variables listed in the project items.
When you create a data binding on a shared variable, you need to browse for item in Network Items and not on Project Items, doesn't matter if item is actually inside the same project.
Hope this help,
ClémentG
(4,704 Views)
Hello ClementG
Sory, but I don't understand what you intend to say with this.
I use for the input to the deploy library a path (on disk). Wat is wrong??
(4,702 Views)
What I mean is when you create your variable from the Project, you can choose to bind the variable to a project item. Instead of that, you should try to bind the variable to a network item.
ClémentG
(4,697 Views)
But I'm not binding the variable to anything.
I doesn't check the option "Bind to Source".
(4,692 Views)
