How to open multi-files at the same time
I mean that it displays the "open explorer" after the click of the browse button, then i sellect two or more files at same time, it opens the files at same time after my pressing the "open" button.
(2,888 Views)
I can't find it any more but an earlier posting talked about the API windows used for multi-files dialog.
Here's the LLB used to have such a dialog. Sorry for the one who posted it earlier, it's his LLB and not mine. I've modified two or three things, thus making the comments french but that's all. LLB is LV70...
Hope this helps !
Julien
(2,869 Views)
I am responding because I just saw a solution to this problem using the "standard" Windows dialog. I have not tried it, but the solution is documented here by Andrey Dmitriev: http://vi-lib.com/user.lib/OpenFileDialogBox.html
Only for use with LabVIEW 7+ and Windows (obviously).
(2,859 Views)
jumarion and C. Minnella, i am out of trouble now, thank you very much!
(2,852 Views)
