How to open multiple subvis (front panels) in atop level vi and adjust their positions 9minimize & Maximize)
Hi Swathi,
I guess that u want to show the front panel of the sub VI's during run time.
Correct??
Do this:
Right click on the sub VI and in pop down menu, select>> Sub VI node Set up>>Here, select the 'Show Front Panel when called' Option and its sub option: "close afterwards if original opened
Do you want to minimize/maximize the shown sub VI's front panel programatically??
Dev
(2,762 Views)
Thanks for ur reply but thats not the problem.
I want to open many sub vis at a time in a main vi and i want to arrange these subvis like cascade,tiles horizontal,vertical.
Could you plz help me out?
(2,745 Views)
Hi Swathi,
you can use a property node to arrange the vi´s. The property you need is: FP -> Position (or Bounds). Sorry, i can´t check it now (i have a german labview version).
Mike
(2,732 Views)
