How to restrict the maximum size of a vi when one maximizes the window?
(2,925 Views)
Hi Swathi,
You could use the vi property node(Front Panel Window Bounds) to set the front panel size.
 If you want restrict during run time, Use the event case "Panel Resize" and set the bounds in that case.
I have attached an image that might help you
Raja
(2,920 Views)
Hi Swathi,
you can use the event "change panel size" to reset it to what you want or you disable the maximize button.
Mike
(2,918 Views)
