How to open solar toolkit in LabView 8.5
I am building a solar cell test system like a student project. I have access to labview 8.5 and i wan't to run the solar toolkit vi at the link below. The toolkit is written for version 8.6 and won't open. Is there any way I can get an 8.5 compatible version?
http://zone.ni.com/devzone/cda/epd/p/id/5918
Thank you if this is possible.
(3,991 Views)
Accepted by atpalmer
I have saved all of these files in LabVIEW 8.5. Please let me know if everything works fine.
(3,944 Views)
I am getting problems with the second set of files, it might be a problem with my LabVIEW, let me fix that and post it as well.
Anna K.
(3,932 Views)
Hello,  Looks to have worked now. I received warnings that the DCPower vi's cannot be saved to a previous version because they are part of the DCPower toolkit. But I believe that these are all included in with the driver which you can download at the link below.  http://joule.ni.com/nidu/cds/fn/p/sb/navsRel/lang/en?q=dcpower
Please let me know if you run into problems.
Anna K.
(3,914 Views)
Thank You Anna. I can now open the VI's. I don't have any hardware installed yet so I haven't tried the SMU version but the no hardware works just fine.
(3,887 Views)
