How to optimize this labview fpga vi??
You shouldn't need to insert pipeline registers if you are writing code within a While Loop. The pipeline stages are mostly useful within a Single-Cycle Loop where you (as the user) must explicitly define where the registers are located.
Message 51 of 54
(859 Views)
thank you
Yes this is what I mean exactly..
We shouldn't need to insert pipeline registers if you are writing code within a While Loop
but I am confuse because the second image was captured from ni tutorial
http://www.ni.com/white-paper/3749/en
so we need to be sure that must we not put any feedback register to reduce path or make pipeline because we already have a reg between element ??
best regards
hi ?Q>
Message 52 of 54
(854 Views)
hi
 i have completed vi for my project.now i want to port it into virtex 4 fpga.What are the steps i should follow so that i can copnvert the labview vi into fpga supported format.
Message 53 of 54
(840 Views)
Unfortunately, LabVIEW FPGA does not support hardware other than NI hardware and the Xilinx University Program Spartan 3E starter kit (for academic purposes only)
Message 54 of 54
(833 Views)
