How to output element from array with time delay and the element is not inside the loop?
The condition is I have the setpoint array where these setpoints will be input to the mass flow controller in further processing. This part of the operation cannot be completed in the loop since I was making improvements based on the current programme, the original programme already had a setpoint input setting. Now I want the Setpoint stores in the array to input one-by-one into the Write Setpoint VI with time intervals. That's the reason why I try to look for a method to output the element from the array with time delay.
Message 11 of 12
(308 Views)
Hi Jerry,
Place the WriteSetpointVI inside the FOR loop shown by Altenbach and you finished your job…
Message 12 of 12
(304 Views)
