How to overlap a 3d curve plot on top of a 3d parametric surface plot
I have created a sphere using the 3d parametric surface vi which will serve to simulate a "Poincare Sphere" is phase-space.  I am collecting data which define sequential points on the sphere. I want to be able to plot these points on the 3d parametric surface plot of the sphere I have created and then have a line connect these sequential points. The line must lie on the surface of the sphere and not cross through the sphere's interior. Essentially I want to overlap a 3d curve plot on a 3d parametric surface of a sphere. Any suggestions?
(3,642 Views)
If you have a shere then you are most of the way there.
If you start reading my postings to this thread
http://forums.ni.com/ni/board/message?board.id=170&message.id=143663&requireLogin=False
reply #7, you will find an example that closly resembles what I think you are asking for.
If that thread and its posting aren't enough, please post back here with
1) some of your sample code saved with typical data as a constant or the default of a control.
2) along with an image of what you think it should look like when its done.
With that information we should be able to advise how to proceed.
Ben
Some
(3,631 Views)
Hello, I'm trying to get just the same. I need to draw a 3D sphere (Poincaré Sphere) and draw points (States Of Polarization) on it. Can you send me the .vi you created to do that? My e-mail is al12179@hotmail.com Thank you very much, I really need it.
(3,490 Views)
I already posted all of that code in the thread I indicated (see reply #7).
CLICK HERE
and down load the zip.
If you use any of that code, I humbly request that you post an example of how you used it so others can learn from your work.
Thank you,
Ben
(3,483 Views)
