Odd behavior of graph
Hi
I'm trying to display the online data in a graph with a fixed origin and a variable end.
The x scale shows time in seconds.
The fixed origin of the x scale is 0. Within the first 15 seconds the data fills out the graph.
When I'm running the attached main.vi the graph is initialized correctly but the x-scale doens't stay fixed on the defined range.
WHY?
Thanks for any help.
Yves
(3,053 Views)
Hi Yves,
I cannot test your vi as the DAQ.vi is missing...
But maybe you should switch on XAxis-Autoscale for the graph?
If you want to display the same on the graph and the chart you have to collect the data for the graph in an array (using a shift register in the while loop)...
Message Edited by GerdW on 10-25-2007 09:36 AM
(3,038 Views)
Hi Yves,
I don´t understand what you want to do with the Part in front of the While Loop?
Because there you set the X-Offset to a huge negativ value!
You should have a look at the example:
charts.vi in the Example Finder!
Best regards
Alex Rudolph
NI Switzerland
(3,012 Views)
Try clicking the "Ignore Attributes" option.
When not checked the charts pick-up the "x" values from the data presented.
Ben
Message Edited by Ben on 10-26-2007 07:29 AM
(3,002 Views)
