change labels of multiple axis in xy-chart
I want to programmatically change the labels of the axes in a xy-chart with two y-axes.
I can easily manage this for the x-axis and the first y-axis. But I can't find how to access the properties of the second y-axis. How to do this?
Steven
LV 7.1 - 8.2
(3,642 Views)
There is a property named "Active Y Scale".
In dictates which of the multiple axis you are going to act on.
Set it to the index of the axis you want to change BEFORE setting the label.
Ben
(3,640 Views)
You would have to set the property "Active Y scale" or "Active X scale".
André
André (CLA, CLED)
(3,638 Views)
Ben, Andre,
Thanks for your very fast reply.
5 stars for both, however I have only 39 posts so apparently I am not qualified to rate your perfect answer Smiley Sad
Steven
(3,631 Views)
