How to parallellize a loop with arrays?
Trying to improve the performance of a program i want to parallellize a loop. This loop uses a vi which returns an array, and i assume this can be of different lengths each iteration. The current solution is a classic Concatenate arrays via shift register disallowing parallellization, but there should be some workaround, right?
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,329 Views)
Accepted by topic author Yamaeda
Hi Yamaeda,
whenever you need to concat elements in an array in a loop you need a shift register, either by BuildArray or ReplaceArraySubset (with a predefined array)...
One possible workaround: When the arrays from your subVI differ in length you should put them in a cluster. So you can use autoindexing to build an array of cluster of array - with the disadvantage of needing another loop to concatenate the subArrays later on...
Is it worth it?
(3,324 Views)
Yeah, that's a good solution, i'll give it a try! If it's worth it? Well the sub-vi does some analysis which should take some time, this is more of a check for possible routes to speed it up. 🙂
/Y
Qestit Systems
(3,306 Views)
If you use the concatenating tunnel, the second loop can be parallelized just fine. 😄
(3,270 Views)
ok, that seems to be a good reason to finally upgrade from LV2011...
When the tunnel supports parallelization you could fulfill the task with just one loop (and without the bundle/unbundle step in between)!
(3,246 Views)
Good point Old creek. However i'm sitting with 2010 right now. It sure improves parallellizability in general though!
/Y
Qestit Systems
(3,233 Views)
