How to pass TCP connection ID into subpanel VI
I am trying to pass a TCP connection ID into a subpanel VI, but wasn't successful.
Here's the function I used:
I was able to pass other control values into the VI but not the TCP conn ID.
Is there any restrictions or other ways I should do it?
Ken
(3,154 Views)
Accepted by topic author kenyu
Hi Ken,
Is 'reference' a TCP connection ID? If so, wire the reference directly to the Ctrl Val.Set invoke node. No value property of the reference needed.
It definitely works with TCP connection IDs.
Hope this helps,
Daniel
Message Edited by dan_u on 02-20-2010 01:17 AM
(3,145 Views)
Hi dan,
Thanks for the reply. Found out that I wasn't putting it in a loop, so the value didn't update.
(3,119 Views)
