How to pass a NULL string into a .net method
Hey everyone,
 I am trying to use this method, and it wants a NULL to query all.
What do I wire into workspaceName? Empty String ("") does not work, just a constant with no characters inside does not work. Creating a byte array with 0 and converting to string does not work. With "does not work" i mean i get an empty array of workspaces, just like when i enter a notexisting workspaceName. I do not get an exception.
The method is working when entering an existing "workspaceName" into the input.
Thx in advance
(5,441 Views)
Accepted by Tesla1977
you cannot send a NULL with LabVIEW directly. If you absolutely need that you would have to create a wrapper DLL, that sends the NULL and you call the wrapper DLL instead of the original .NET DLL.
Christoph
Staff Applications Engineer
Certified LabVIEW Developer (CLD), Certified LabVIEW Embedded Systems Developer (CLED)
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved
(5,383 Views)
OK, thanks for the answer. As this is an absolute standard .net method from Microsoft, can this be implemented into LV or does any internal data handling prevent that entirely?
(5,364 Views)
For future use or other users:
With System.String (in mscorlib) there is the static property "empty" which works perfectly.
(5,344 Views)
If it is for database related, you can try with "DB Tools Null" function (Connectivity->Database->Advanced).
Sanad MM
(4,086 Views)
