How to perform some operations after pressing the X button
Hi. This is a basic question about building a "pro" application.
Let's suppose I have an application (VI or built executable), which is commonly structured as a while loop.
When the user wants to exit, I need the application to perform some operations (file writing and closing, for example) and then exit. I can easily put a "close" control on the front panel and that would do it, but now I would like to do it with the X button of the title bar, as most "pro" applications do.
As you may know, the problem is that when you press the X button the aplication exits inmediatly aborting the execution, whithout performing the desired operations.
Any comments appreciated. Thank you.
Daniel R.
(2,631 Views)
You can use an event structure with a filtering event for "panel close?" In that event case, you could do whatever you want (e.g. create a popup) and then you can either process or discard the panel close operation depending on your needs. Try it!
(2,628 Views)
Perfect. That did it.
Thank you!
Daniel R.
(2,610 Views)
