How to place a table at a bookmark location in a Word document?
Using the Word Easy Table.vi to place a table in a Word document is a very effective way to place a lot of tabular data in a printed report.  However, it places the table at the end of the document where I don't want it.  How is a table placed somewhere else in the document such as a bookmarked location?
I'm using LB 8.5 and Report Generation Toolkit 1.1.2.
Dave
(2,895 Views)
If you use "append table to report.vi" instead of "Word easy table.vi" you can append a table at a bookmark. First you have to make a word template with the boomarks you are going to use. Look at the appended example, in this example I use a template called c:\temp\lvtable.dot and a bookmark called LVtable.
(2,875 Views)
