How to place markers on the plot ?
Dear All,
I have a graph where i am plotting 4 channel data.
I want to put markers on each channel.
By Markers, i mean small dots on the plot which gives me the x-difference between the two. And, one more thing, the markers should only move on the plot and not elsewhere.
I know something can be done with the cursors in the graph pallete. but, they take a lot of place in the graph. 1 horizontal and 1 vertical line for each plot would add to alot more confusio.
I am putting a picture to make things more clear of what i want. Black line represents the data and on it i have placed 2 red markers.
Juat have a look at the pic and let me know if that thing is possible in LabView??
Message 1 of 10
(4,120 Views)
Yes, it is possible and you would use cursors. You can customize the appearance of a cursor and the vertical/horizontal lines are optional. Make the Cursor Legend visible and create a cursor. Right click on it and select Attributes. You will be able to see the different options. All of these are also settable with a property node.
Message 2 of 10
(4,106 Views)
Definitely try thte cursors first, as Dennis suggests. If that doesn't work for you, you can always use annotations. Check the LabVIEW Help and the shipping examples.
Message 3 of 10
(4,102 Views)
Thanks alot for the sloution.
Yes, with the Attributes i just got what i was looking for.
but somehow i couldn't get how to play around with them via property node.
I have placed 2 cursors on the plot. i want to display the x-difference between the 2 cursors. With the property node, i was just able to manipulate the 1st Cursor, and not the second. Any idea how can i play around with the 2nd Cursor.
And also i want an indicator just above the 2nd Cursor which shows the x-difference between the 2 Cursors. How is this possible?
Message 4 of 10
(4,074 Views)
Use the active cursor property as shown in attached VI
Read each cursor's x co-ordinate using 'cursor.PosX' property node and find their difference
Dev
Message Edited by devchander on 09-10-2008 06:33 AM
Message 5 of 10
(4,059 Views)
Thanks alot.
I got the way.
Is there anyway i can place an indicator just on top of the 2nd cursor(and moves along with it) which displays the x-difference b/ween the 2 cursors ?
I can place an indicator on top of the cursor but its position remains static. I want the indicator to move with the cursor.
Message 6 of 10
(4,052 Views)
Simpler Method>> just keep renaming the 2nd cursor with the x difference Smiley Wink
Look at at attached VI
Ofcourse you could do further string concatenations/ modifications to customize what you want to display
Message Edited by devchander on 09-10-2008 07:21 AM
Message 7 of 10
(4,046 Views)
Lollsss...
Your simpler method is just too simple that my mind aint allowing me to implement it.  :smileywink:
i was looking for some tedious methods to do d same.
you have put my mind on HALT now.  :smileysad:
Message 8 of 10
(4,035 Views)
ritesh024: "you have put my mind on HALT now.  :smileysad: "
Is that good news or bad news????? Smiley Very Happy
regards,
Dev
Message 9 of 10
(4,032 Views)
It is bad until i found a new problem .:smileywink:
Ritesh
Message 10 of 10
(4,028 Views)
