multi dimensional arrays and table indicators
I'm wondering how I can write a string array with more than two dimensions to a table. Specifically what I want to do is this:
I am currently writing a 2d array to the table. Column 1 consists of the channel names from my DAQmx task and Column two is the current data for those channels. What I am trying to do is to split that up into a '2 column view' so that:
Column 1: 1st half of  the channel names
Column 2: 1st half of the data
Column 3: 2nd half of the channel names
Column 4: 2nd half of the data
Here are the steps that I've done to try and make this work:
I've split the original 2d array in half by using the 'delete from array' vi which outputs both parts that I need then putting that through the build array vi.  When I do this, the data wire out of the build array vi is of type '3d array' I'm thinking it should be a 4d array and I'm not sure why it isn't. When I try and wire the table to this it will not allow it because the sink type is for 2d arrays.
Any advice or suggestions?
(2,677 Views)
Hi scrook,
that you get a 3D array is absolut correct. Smiley Wink If you have two 2D array, then the next dimension is 3D. Draw a 2D array on one paper (your first part) and a 2D array on another paper (your second part). If you combine them, put one on the other you get a 3D array. Smiley Wink
But you need a 2D array.
See the attached example, pelase.
Hope it helps.
Mike
(2,675 Views)
Mike,
I see what you mean. Thanks for giving an example of how to do it correctly.
(2,663 Views)
