excel
Hi
attach see file :  how can i read all data from excel file , i can read only number
all string show me 0
thans
(3,142 Views)
Hi elyan,
which LabVIEW version do you use? If you have LV8.x then you can simply change the polymorphic instance to string. If not, you can copy the vi, and change it to read strings.
Hope it helps.
Mike
(3,135 Views)
Hi mike :
I have labview 8.5 .. can you help me with this issue , i try what to said but its didn't help
(3,131 Views)
In 'read from spreadsheet file.vi', select type as String
And why are you reading the file inside a loop and indexing out read each column??
You can read the whole file in just one go
Look at atached VI
(3,130 Views)
thanks
(3,126 Views)
