How to place mouse pointer on top of a front panel control or indicator?
I need to programmatically set the mouse cursor position on top of a control when the program starts.  Attached is a simplified version of what I want to do.  In the example I want the cursor to be on top of, or near, the Control Point boolean indicator.  I've tried using panel and screen coordinates but neither gives the correct position.  I think I need to add or subtract some other value, perhaps the screen coordinates of one corner of the Labview front panel but I can't figure out how to proceed.
(2,112 Views)
Accepted by bgoolsby
Can't open your VI (we're locked at no later than LV 2021).
Maybe you can extract what you need from the attached files.
(2,102 Views)
Here's the VI in LV 2019.  I'll check out the VIs you sent.
(2,084 Views)
You should use the Window Bounds property instead. Programmatically Move the Front Panel to a Desired Position Using LabVIEW
However, I haven't figured out why we need to subtract a certain number.
https://tmesystems.net/
(2,064 Views)
This works perfectly - thank you!
(2,059 Views)
