How to place pipes, pumps and valves in LabVIEW 8.5?
I'm an Undergraduate student of Electrical Engineering and simulating the Lube Oil system for the gas turbine generator.
I need to know how I can place the pipes, pumps and valves in LabVIEW 8.5??
Also I need to know if a control symbol on front panel (e.g. a pipe) can be rotated/tilted or not??
Replies awaited.
Regards
Message 1 of 9
(9,520 Views)
Pipes, pumps, etc. are part of the DSC module. They have all the controls of which you speak in 4 orientations.
PaulG.
Retired
Message 2 of 9
(9,517 Views)
There is a Multi-Segment Pipe control in LabVIEW, but it isn't on the palette.  It's a boolean and the color indicates the state.
The attached VI contains one.
Note in addition to changing the size/shape with the grab-handles, you can right-click to add/remove segments.
Message 3 of 9
(9,505 Views)
Here is a set of built-in decorations that aren't on the palette.
Message 4 of 9
(9,480 Views)
Thanks for your support. 🙂
There's a little technical hitch. The decos file is built on LabVIEW 10 and, as I mentioned, I have 8.5.
Kindly repost it.
Regards
Message 5 of 9
(9,461 Views)
8.0.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 6 of 9
(9,455 Views)
Thanks alot... 🙂
Message 7 of 9
(9,451 Views)
I'm a b.tech student.I'm doing my project on labview.I want to place pipes ,valves and pumps in my front panel.I have a labview of 2012 version.kindly post necessary link compatible with labview 2012
with regards
Message 8 of 9
(9,015 Views)
Did you try the ones linked above?  LabVIEW code is generally backwards compatible so the old versions should open fine in 2012.
Message 9 of 9
(8,997 Views)
