How to plot a 3D graph using pixel values and XY coordinates? LabVIEW Vision
So using IMAQ modules, the VI "ImageToArray" gives me a 2D array with the pixel values for each xy coordinate. I assume I can translate these pixel value to the z coordinate (height), but then what addon or VI can I use to plot the 3D visualisation of this?
(3,273 Views)
Hi Jitesh,
what about a simple IntensityGraph?
(3,265 Views)
There is the IMAQ 3d view, or you can search the palette on the front panel for "3D surface" which will give you the Plot Helper.vi.
(3,241 Views)
Intensity graph is already what I have, but I want to convert the intensity into the Z axis (3D view)
(3,233 Views)
