‎08-14-2019 04:26 AM
So using IMAQ modules, the VI "ImageToArray" gives me a 2D array with the pixel values for each xy coordinate. I assume I can translate these pixel value to the z coordinate (height), but then what addon or VI can I use to plot the 3D visualisation of this?
‎08-14-2019 04:28 AM
‎08-14-2019
04:46 AM
- last edited on
‎07-24-2026
09:16 AM
by
Content Cleaner
There is the IMAQ 3d view, or you can search the palette on the front panel for "3D surface" which will give you the Plot Helper.vi.
‎08-14-2019 05:25 AM
Intensity graph is already what I have, but I want to convert the intensity into the Z axis (3D view)
