How to plot a XY graph of voltage Probability Density Function vs Voltage on front panel
I want to create a pdf vs voltage plot on the front panel to check the distribution of my voltage-time data (check if it is Gaussian or not). What exactly will I need to insert into my block diagram inbetween the DAQ Assistant and the plot itself?
(2,994 Views)
Any tips on this would be greatly appreciated.  Smiley Happy
(2,981 Views)
Hi AT12,
Have you had any progress since you posted your message? XY Graphs can be used for single or multiple plots - so it depends on what kind of of result you are looking to get. Have you seen the XY Graph.vi example that ships with LabVIEW? You should be able to find it by searching for "XY" in the NI Example Finder. The example VI shows 4 different ways of plotting to an XY Graph, depending on what you're looking for.
Imtiaz Chowdhury
Project Manager
Green Running / Austin Consultants
(2,935 Views)
