I was unable to connect my ni crio 9022 and the error occured is " failed to connect to real time target"
I was unable to connect my ni crio 9022 and the error occured is " failed to connect to real time target" when i tried to connect it in  a project and also  it is appearing well in the MAX with the assigned IP address but there it is indicating that no software installed but when i tried to load the software it is there in the target .
status led in the crio in blinking twice per second
Is this because of any software loading problem , do i have to uninstall and install the software again?
(2,671 Views)
I'd turn on the console out, and watch for clues during boot.
If that goes nowhere, reformat flash, and reinstall standard software + addons.
(2,663 Views)
Why not read the manual to find out what the flashing status LED means ? Here is what it says:
"The controller has detected an error in its software. This usually occurs
when an attempt to upgrade the software is interrupted. Reinstall
software on the controller. Refer to the Measurement & Automation
Explorer Help for information about installing software on the
controller."
Consultant Control Engineer
www-isc-ltd.com
(2,661 Views)
