How to plot a function on the sphere?
I have a 2D array and I want to plot it on a sphere like a "termal plot" . The rows and cols of the array are already the elevation e azimuth angles. How to do it?
The image below shows an exemple of sphere plot.
Frederico Araujo
(3,944 Views)
The parameteric surface graph has an input for a color matrix as 4th dimension. I can post an example later. What's your LabVIEW version?
(3,932 Views)
It's LabVIEW 11.0.
(3,922 Views)
Accepted by freddearaujo
Here is the relevant part of my old code. You would need to change the mapping of one dimension to elevation instead of angle. Shouldn't be hard.
(3,885 Views)
