How to plot a peak value of signal vs time in labview
I have  pulses coming at a repetition rate of 1kHz and I am detecting them using a Photodiode connected to a picoscope. I want the peak vale of each pulse and want to plot it as a function of time.
How to do it?
(2,959 Views)
Hi niftp,
read the (analog) data using your PicoScope.
Then analyze the data to find your peaks.
Then plot the found X and Y values using a XY graph…
(2,952 Views)
I want a real time peak max vs time plot.
(2,932 Views)
Hi niftp,
simple example of plotting y vs x values:
What have you tried?
Where did you encounter problems?
Why don't you attach a VI (with some example data)?
(2,929 Views)
