X-NET CAN message direction
Dear
According to the example given by NI I have created a tree that Displays all the Content of a .dbc file.
I works great but I cant find out whether a message is a send or receive message.
Does any one of you ever tried to find that out or know how to find that out?
Please have a look into the attached example for more Information.
Best regrds
Martin
(4,837 Views)
CAN message are usually message that are send in a regular interval.
You might have to read continuously the CAN bus to retrieve any message.
(4,830 Views)
Beg me pardon but I don't takl about CAN message Transfer.
I'm talking about the .dbc file anaysis.
Within the .dbc file each message Can be identified as send or receive message.
What is missing is a indicator or property for this inforamtion.
(4,826 Views)
Hi Martin,
The Tx/Rx information is coded in the dbc file by assigning a message to a certain device/network node ("Netzknoten" in my German CANdb++ tool).
Unfortunately I could not find a way to read that information from XNet (but I don't have much experience with XNet).
You may just read the dbc file as it's a simple text file and parse the lines starting with "BO_" to read their device assignment. Each "BO_" line (BO = "Botschaft" (German) = "message") contains ArbID, message label, payload byte count, assigned network node.
(4,825 Views)
Gerd
thats exactly what I need.
I have written a .dbc file reader but this information seams to be not available.
The example is available at www.digiinst.de
Did you hear something new about this issue?
Regards
Martin
(4,757 Views)
Hi Martin,
no, in the last month I did not hear anything new. (I also didn't ask for news.)
For my use case (cRIO with NI9853, doing CAN message filtering in the FPGA) I usually parse DBC files "manually" by converting them to plain text/csv files…
Thanks for that XNet example!
(4,755 Views)
Dear Gerd,
I have enhanced the Project by a path based .dbc database selection and now you can choose whether you want to see tx or rx data.
You can download the Project from here:
https://www.digiinst.de/p/read_can_dbc
Best regards
Martin
(4,730 Views)
