How to plot the graph of signals from two channels to waveform chart and export the outputs to excel file
Dear all!
I am new in Labview and DAQ systems. I would APPRECIATE any help from YOU.
I would like to plot the graphs of two lvdts displacement up to time change on A ONE SINGLE Waveform Chart and finally get the results in excell file.
I face some problems pertaining to type inconsistency when converting from dynamic data.
DAQ: NI USB 6210
LabVIEW version:  LabVIEW 2017
The source code and the screenshots of settings of certain blocks have been attached.
(3,900 Views)
Hi Frank,
Then why do you converrt the DDT wire to a single waveform, when you want to plot both waveforms/signals?
You should convert to an array of waveforms to get your both signals…
(You should get rid of that DAQAssistent, it will limit you in the end.)
(3,878 Views)
And when you get rid of the Dreaded DAQ Assistant, do not bring back its Evil Twin, the Dynamic Data Wire!  Stick with an Array of Waveforms which will automatically plot "correctly".
Bob Schor
(3,863 Views)
Thank you for the response.
I changed Resulting data type and get rid of some elements, but  I lost time column in my result file.
You advise me to change DAQ assistant to something, could you tell me to what?
(3,849 Views)
You did mention about changing DAQ assistant to something, what namely I got to change it to?
(3,847 Views)
All I want is just read the voltage values from two channels during certain TIME and:
1. Plot the on the SINGLE waveform chart
2. Save the result values to a file (csv, txt, excel) with following structure:
time| voltage1| voltage2|
I have been looking for relevant examples but without success. If you know please, could you give some link to specific examples
Sorry if my questions looks silly or wierd.
(3,841 Views)
Hi frank,
1. Wire the waveform array to your chart…
2. Configure the ExpressVI in the correct way - or do your own data formatting:
(There are other options as well, but that one is done quickly…)
(3,831 Views)
