waveform graph
In a waveform graph, if x axis is given timestamp values, how to find all the y axis values in between two particular timestamp values?
(3,003 Views)
Hi ash,
In a waveform graph
Simply set the "Interpolation" style of your plot to "connect points" mode to see "all y values in between"…
Use Interpolate1DArray on our input data…
(2,982 Views)
Hi Gerd,
If i use interpolate function i can give only one input. How to give the range ( max and the min)?
(2,976 Views)
Hi ash,
when you want to repeat the same operation multiple times you should use a loop…
What about using a loop to get the Interpolate1DArray output for several X values between Xmin and Xmax?
(2,973 Views)
