How to plot this curve ( R-X curve for a distant relay )
The file is attached.
(2,433 Views)
Hello Sukhmeet,
It's fairly simple to make.
Just use the XY graph and two arrays.Remember to make the first point also the last point otherwise the line will not connect.
If you want to make more plots in the same graph:
Koen
UnCertified LabVIEW Student
Mistakes are for learning, that's why suggestions are always welcome!
(2,419 Views)
