How to plot two points simultaneously on image?
I want to plot two points simultaneously on an image. I tried using IMAQ overlay point and IMAQ Light meter for point. But when I try to plot two points using either of these two VIs, I find not even one point is plotted. How to resolve this?
(4,142 Views)
Accepted by intensity
If your image is zoomed out, the point size may be to small to allow a proper drawing of the point. Otherwise IMAQ overlay point works flawlessly...
Message Edité par chilly charly le 01-31-2009 11:40 AM
Chilly Charly    (aka CC)
(4,124 Views)
Thanks for the reply. The program works fine. But as you said, the points are too small and hardly visible. How can we magnify them? Is there any method to show the points visible?
(4,073 Views)
Why don't you draw bigger points ? You could use the IMAQ Overlay Oval to draw a circular point.
(4,060 Views)
Hi, I tried plotting the two points seperately instead of array and it seems to work perfectly now.
(4,057 Views)
