How to prevent dummy data from being displayed on the XY graph
I am setting up a program which will run up to 5 tests for different input condition. The program allows the user to opt out of certain tests. As this will result in 5 sets of data with dummy data for the test being opted out, how do I prevent them from being displayed on the XY graph? Also, is it possible to change the names of the plots programmatically.
(2,484 Views)
If you don't want something to appear in a graph, just don't wire it, you can extract dummy data from the input depending on your option.
Yes, you can change a plot's name programatically, using attribute node plot name, but be sure you select the plot you want to change as active plot before.
Hope this helps
(2,484 Views)
