How to program Pickering 50-115-122 relay cards
Hello
In MAX it is showing the correct address,slot and bus. like PXI6::14::instr
I downloaded the drivers from pickering website PILPXI and PIL40Vi
In PILPXI one palette named card ID, I given the card number then it is showing the exact Bus and Slot number.After that I connect a Opswitch. there one subunit showing the problem. default its value is one. But when run the program error message it is showing the Error 17 occured a PILPXI Op crosspoints.vi drivr status(17) function call incompatible with  subunit type or capabilities.
In PIL40vi showing some other error that is model no in the string is like 40 -115 etc. That I changed with exact one 50-115-122/121 etc. after that also showing some error messages. some times showing IVI not loaded.
some body please help me
Message Edited by gireesh on 03-26-2010 10:14 PM
"Thanks with regards "
by
..........Gireesh..........
(3,125 Views)
I am aware that the pickering .ini file is somewhat out of tolerance.Smiley Wink
I've attached one that worked for my needs at one time.
It could be a problem with the ivi set-up in MAX  Can you post a screenshot of the MAX Driver session general settings?
(3,097 Views)
