How to programmatically add UDVs to project?
Hi all,
I have successfully used something like this to programatically add shared variables to an LVLIB (the code assumes that the library associated with the Container Reference contains at least one variable):
An example output would be:
  • Container Name: "MyLibrary.lvlib"
  • Variable Name: "Variable1"
  • Variable Path: <blank>
  • Variable Type String: "Variable"
(I notice that there is no way to specify the data type of the variable, and LabVIEW creates a DBL variable in the LVLIB by default.)
However, if Container Reference is associated with a "User-Defined Variables" container, then I get Error 1 at the Invoke Node ("LabVIEW: An input parameter is invalid"). A example output is:
  • Container Name: "User-Defined Variables"
Questions:
  1. Does the error occur because LabVIEW is trying to create a DBL variable (which is not allowed with UDVs)?
  2. How can I programmatically add UDVs to my project?
Thanks in advance!
Certified LabVIEW Developer
(4,572 Views)
What is the scope of your project? How will you be using these UDV's?
(4,531 Views)
Hi!
Did you find any solution?
I have exactly the same problem....
Thanks for your answer...
(3,961 Views)
Unfortunately, I didn't find a way to add UDVs to a LabVIEW project via VI Scripting, and I stopped trying.
(3,958 Views)
thanks for your quick answer...
Nobody from NI ? or a labview champion here ?
For my test i have something like 256 user variable to create, and i thought it will be easier doing that programatically...  I don't understand why u can't do that in the project , there is a multiple variable editor, but you can't add multiple variable at once, you have to create them one by one... maybe it's linked with the fact you can't do that programatically...
(3,953 Views)
