How to programmatically build applications in a usable way
We have about 10 projects with each at least 1 build definitions, building these manually is tedious.
Looking into automating this I came across https://forums.ni.com/t5/Example-Code/Programmatically-Build-Applications-in-LabVIEW/ta-p/3996198. This has two problems making it not really usable:
  •  it uses application arguments, so you invoke it like LabVIEW.exe programmaticbuild.vi -- my.lvproj, but suppose you have labview already running and use that command it will pass the arguments of the already running instance
  •  to counter that I made a standalone application from programmaticbuild.vi, however that fails with
    Error Code: 1025
    Error Source: Open VI Reference in NI_App_Builder_API.lvlib:Build (path).vi->BuildTargetBuildSpecification.vi->programmaticbuild.vi
Ideally a solution to the second problem would be ideal, however a nice way around the first one would already be a good start. Any ideas? Thanks!
(7,251 Views)
If you already have LabVIEW running, you can use VI Scripting functionality to invoke a build from a build specification. Scripting allows you to automate a lot of functionality from LabVIEW (even things thing wiring up terminals!).
For the second error - there isn't enough information in your post to figure out what's going wrong - maybe a path issue? Can you post a simplified version of your project/files that replicates the error?
(blog)
(7,228 Views)
This article from our friends at JKI is old, but still good - http://blog.jki.net/jki/can-you-build-your-application-in-one-click/
Jim
(7,217 Views)
@SamSharp I've attached the programmaticbuild.vi, only slightly modified from the original, and a project which just creates a standalone application from it.
Called from the commandline like ProgrammaticBuild.exe /path/to/my.lvproj, the generated logfile contains
ProgrammaticBuild
/path/to/my.lvproj
/path/to/my.lvproj was unsuccessful for build.  Error Code: 1025   Error Source: Open VI Reference in NI_App_Builder_API.lvlib:Build (path).vi->BuildTargetBuildSpecification.vi->programmaticbuild.vi<APPEND>
VI Path: <b>_bin\vi.lib\AppBuilder\BuildTarget.vi</b>
I don't know for which vi the 'Open VI Reference' error is
The exact same command works when ran through labview, i.e. if I call  "C:\Program Files (x86)\National Instruments\LabVIEW 2013\LabVIEW.exe" programmaticbuild.vi -- /path/to/my.lvproj the logfile has
/path/to/my.lvproj
/path/to/my.lvproj was built successfully.
@Jim interesting but it also uses BuildTargetBuildSpecification.vi, so will probably generate the same error I'm facing now
(7,210 Views)
Accepted by Stijn
By definition your second option won't work because one of the things stripped out of a standalone executable is the ability to compile code.
In terms of option 1, the issue is whether the list of command line parameters would get updated with additional "launches". I don't know if it would, but I never tried it either...
The utility I wrote just asks for a project name when it starts.
Do you do this a lot? It might be worthwhile to create a sort of build server that automatically rebuilds things after any changes to a predefined list of projects.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(7,206 Views)
Aha, that explains a lot.
We're planning to make building of our Labview projects part of a continuous integration, so yes we're going to build them often.
Another workaround for option 1 would be to write the projects to build to a file which is then read by the vi.
But the idea of a 'server' application which builds is probably the most viable. Thanks!
(7,197 Views)
The thing is, as a practical matter the server would likely need to run on a separate computer since building executables consumes all of an instance's time.
Mike...
LabVIEW Champion
(7,190 Views)
