How to programmatically position an element in a cluster
Hello I was wondering how I can programmatically position an element (e.g. numerical control) which is a part of a cluster. My goal is to position the control to: Case 1: Bottom Center of the cluster Case 2: Bottom Left of the cluster Thanks. v-k
(3,487 Views)
Accepted by v-k
Hi v-k
You can do it using property nodes of the control.
(3,468 Views)
Thank you Javed.
Your suggestion worked!
(3,422 Views)
You are welcome.
(3,395 Views)
