How to programming LabVIEW to create Temperature application like this VDO?
Message 11 of 21
(2,236 Views)
A little bit more work but perhaps more flexible -- what about drawing the values into a picture and wire that into a PlotImages.Front property node?  This should allow the text spacing to adjust as needed to accommodate different array sizes, within reason.
Message 12 of 21
(2,221 Views)
Thank you very much Mancho00.
Best Regards,
Nirut
Message 13 of 21
(2,216 Views)
Do you know what name of property node to ON/OFF wireframe, ON/OFF Text temperature value?
Best Regards,
Nirut
Message 14 of 21
(2,215 Views)
I try function to export data in the intensity graph to excel file, all data same as the 2D array. So i think the intensity graph should able to show ON/OFF wire frame and ON/OFF text(data in each cell of intensity graph).
Anyone can solve these?
Best Regards,
Nirut
Message 15 of 21
(2,212 Views)
Now i can visible/no visible of text on the intensity graph but cannot visible/no visible wire frame of x-scale, y-scale of the intensity graph.
Any can do visible/no-visible wire frame of x-scale, y-scale of the intensity graph?
Best Regards,
Nirut
Message 16 of 21
(2,205 Views)
Now i can do show/no-show grid and show/no-show text on intensity graph already.
Thank you very much everyone.
Best Regards,
Nirut
Message 17 of 21
(2,199 Views)
I don't really understand what you mean by " wire frame of x-scale, y-scale of the intensity graph".  Are XScale.visible and YScale.visible what you're after?   Please re-ask your question in way more detail.
Message 18 of 21
(2,179 Views)
Hi Zwired1,
I mean X-grid, Y-grid.
Best Regards,
Nirut
Message 19 of 21
(2,176 Views)
Waaaaaaayyyy more detail.   Describe exactly what you want.  What is the current VI doing that you wish it weren't or vice-versa? Aren't you already turning on and of the grid using your "SHOW GRID" Boolean control?
Message 20 of 21
(2,174 Views)
