How to properly generate a sin wave and take it fourier transform?
I am trying to take a digitized sine wave and then plot the magnitude and the phase of its FFT spectrum separately. However, the phase plot I am getting does not seem to be correct. I have attached my VI for reference.
Message 1 of 15
(1,537 Views)
Your Vi is one version newer than I have so I can't open it.
Anyway, what results you are expecting doing a frequency (FFT) analysis on a sine wave?
A sine wave only contains the fundamental frequency. Try a more complex waveform.
=== Engineer Ambiguously ===
Message 2 of 15
(1,495 Views)
When attaching a VI, make sure that all controls have typical default values. Currently, your frequency, sampling rate, and # of samples are all zero. Please tell us what input values you are suing and what you expect as result.
You are using an FFT function that expects a waveform, but you give it a naked 1D array, i.e. no timing information at all. The FFT thus assumes a dx of 1. (did you notice the red coercion dot?)
Also make sure to place a small wait inside your loop (e.g. 100ms) because it seems pointless to repeat the same calculation millions of times per second, burning 100% of a CPU core.
Message 3 of 15
(1,482 Views)
Thank you for the suggestions. I am using the following values:
No. of Samples: 100
Signal Frequency: 100
Sampling Rate: 1000
Message 4 of 15
(1,477 Views)
What I dont understand is the phase plot. Isnt it suppose to be at pi/2? Here is my block diagram:
Message 5 of 15
(1,476 Views)
Wild guess: try increasing the resolution of your input signal.
Here the sine does not seem very smooth:
Raphaël.
Message 6 of 15
(1,470 Views)
There are two main issues:
  • Your FFT by default applies a windowing function, so eliminate that. It is designed for real signals!
  • You should make sure that your signal has an integer number of cycles to avoid spectral leakage
See if this can give you some ideas:
Message 7 of 15
(1,449 Views)
I have been asked to used the sin function and not the sine waveform generation sub vi
Message 8 of 15
(1,414 Views)
You can built your array into a waveform by just defining dt, right?
Message 9 of 15
(1,404 Views)
yes, that should result in an array
Message 10 of 15
(1,398 Views)
