How to protect FPGA IP?
Hi Guys,
I've developed a FPGA application and build the VIs as a bitfile. I am wondering how to protect it?
If others buy my product with the same hardware and just copy my bitfile, it will work too, right?
Is there any FPGA unique hardware related ID that I could get using LabVIEW? In this way I could use a simple ID related protection method and build it into bitfile.
Anyone know about this? Many Thanks!
Message 1 of 11
(5,751 Views)
Hi Bruce,
    The standard way to protect your work at the level I believe you are aiming at is to password protect the block diagram. This way the customer could still run the program in interactive mode and compile it for their particular FPGA, but can't change the functionallity or see the implimentation details. More difficult though is enforcing a license and preventing privacy. You could imagine making a physical dongle that would hook up to a couple IO lines on the FPGA and prevent the program from running if it was missing.
Password Protect Block Diagram
Good luck!
-Gabe
Message 2 of 11
(5,744 Views)
Thanks! GabeG,
Dose Physical dongle means some specified IO wiring to an external equipment?
Imagine that you buy a CompactRIO from me to do some analysis. And you don't even have to buy LabVIEW, because I set the CompactRIO to auto run.   A turn key solution.
But there is FPGA bitfile in the compactRIO you could access. and you know the hardware package and wiring. So you might be able to recreate this system without my licensing.
How could I stop it from happenning?
Message 3 of 11
(5,738 Views)
Accepted by BruceL
Hi Bruce,
    In the FPGA code, you could programmatically read the cRIO module serial numbers and check that they are the same every time the system starts up. Of course if a module goes bad, you have to ship them a new module and bitfile. There are various USB style dongle manufacturers you could probably get to work without much difficulty: http://www.microcosm.co.uk/dinkey_pro.php. It really depends on whether you're trying to make it difficult to pirate or impossible. Selling a complete hardware package like you're describing is probably already pretty safe, unless you plan to charge a lot for the value added by your FPGA IP.
Message 4 of 11
(5,715 Views)
Yes!
Read C module ID is the easist solution. Cool. Thanks.
Message 5 of 11
(5,709 Views)
this may also help
http://www.ni.com/example/31074/en/
Message 6 of 11
(5,674 Views)
@GabeG wrote:
Hi Bruce,
NI has said that VI password protection may not be secure enough for some users, and for greater security block diagrams can be removed.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019LvFSAU&l=en-US
In my opinion I would not choose to password protect a VI because I feel it isn't secure enough for protecting IP.
Message 7 of 11
(5,625 Views)
Personally, I would never purchase any code that has had the block diagram removed. Did this once and when the seller disappeared, the code was useless when I upgraded.
Message 8 of 11
(5,623 Views)
As a user of the software, I would agree with you.  As a manager of a software group trying to protect IP, I would find the password "protection" provided to be less than adequate.
Message 9 of 11
(5,620 Views)
I would use the licensing and activation toolkit before removing block diagrams.
https://www.ni.com/en/support/downloads/tools-network/download.third-party-licensing-and-activation-...
Message 10 of 11
(5,609 Views)
