How to put in column string
I have a file like this :
G0 Z   0.000
G1 Z   0.000
G1 X4082.009 Y5013.133
G1 X7505.601 Y5013.133
G1 X7505.601 Y3783.510
G1 X4981.293 Y3783.510
G1 X4981.293 Y1245.442
G1 X7521.378 Y1245.442
G1 X7521.378 Y   0.000
G1 X4082.009 Y   0.000
G1 Z   0.000
G0 Z   0.000
M9 M5
It's a gcode file, I would like to put each axis on a different column. For this example it will be like this :
For X
4082.009
7505.601
7505.601
4981.293
4981.293
7521.378
7521.378
4082.009
For Y
Y5013.133
5013.133 3783.510 G3783.510 1245.442 1245.442 0.000 0.000
For Z
0.000
0.000
0.000
0.000
I tried to do like I made on my VI but this is not what I want.
Can you help me ? Thanks
(4,992 Views)
You used the wrong delimiter, and Scan From String is your friend.
Jim
(4,954 Views)
Thanks for your help, but what do you use for the "status" box ?
(4,931 Views)
That is an Unbundle by Name.
I would recommend looking at the online LabVIEW tutorials
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
(4,928 Views)
Look at Scan from String (drop it on your own Block Diagram, right-click and choose "Help" to learn about its inputs and outputs).  Notice the Error Line?  That is a Cluster that contains three parts -- Status (True if an error), Code (the Error Number), and Source (a string describing where the error occurred).  The code is designed to "do something when Scan From String does not return an error".
However, about 5 years ago (I'm guessing), NI "enhanced" the Boolean Controls to allow them to accept an Error Cluster as an input and treat it as though it was just the Error Status.  Thus you can do the following:
Just take the Error Line, wire it directly to a Boolean "Not", and you get (directly) the Boolean "Not an Error".
Bob Schor
(4,891 Views)
It's almost November, but you don't need to be an American citizen to vote for this - http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Conditional-indexing-should-accept-Error-Cluster/idi-p...
Jim
(4,873 Views)
