Problem with Labview and Nemesys (Cetoni ) Integration with Qmix SDK elements
Hello ,
Iam trying to interface the Nemesys syringe pump(starter module ) with labview using Qmix SDK software . But am getting the error
-515 error code, which is
"labbCAN_Bus_API.lvlib:Error Converter (ErrCode or Status).vi<ERR>
Unexpected exception during program execution
<b>Complete call chain:</b>
labbCAN_Bus_API.lvlib:LCB Open.vi
Untitled 1"
I have reinstalled the software and did every thing but am not able to find the error ! I have attached the test program pictures .
Thanks in advance
Tanveer Ahmed Shaik
(4,258 Views)
Hello ,
Untitled 1"
Thanks in advance
Tanveer Ahmed Shaik
(4,264 Views)
Accepted by topic author tanveer1993
Did you already contact Nemesys and Qmix for support?
The error is a custom error, so it must be generated by some third party software part. As you mentation Qmix software, i would try to get further information about the error from the vendor of this software.
As the custom error text states some CAN related text, it is possible that your CAN configuration is incorrect.
Norbert
Norbert
Expert: Geometry
(4,099 Views)
