How to put the break at the first place of execution While Loop
Hello everybody,
I have a problem with a while loop.
I made the interface of a tic-tac-toe game with labview.
my problem is that after the computer has won or there is a draw, that the board has to be updated, which i do by shift register.
My problem is now though, that there isn't a break after i updated the board. I have to click one more time on the board(and execute the whole VI) before the break sets in.
so my question is, how can i put the break in a way that the condition is checked everytime BEFORE the VI runs?
Thank you very much
(2,307 Views)
You need to post your VI so we can understand what you are talking about.  When you mention "break", it sounds like you are talking about a breakpoint which is used to help debug a VI.  But your description talks about normal operation of your VI.  So what are you talking about?
(2,292 Views)
The correct way is probably to use a state machine architecture. Simply enter the idle state when the game is over.
(2,284 Views)
