How to query a dynamically loaded subVI for its input terminal names?
I have an application where I am using dynamically loaded subVI's and I need a way to query the subVI for its input terminal names.  I will be using many different subVI's now and in the future and the terminals will not be known.
Any help would be greatly appreciated.
Thank you in advance!
(4,222 Views)
If you have the reference to the instance of the SubVI, then you can use the VI.Panel.Controls[] property to get an array of all of the control/indicator references. You can then check the 'indicator' and 'label' property to determine the name and find out if it is a control or indicator.
There is also a VI scripting property for 'is on connector pane' but this probably won't work in a built application.
(Typically, if I am dynamically calling VIs, I use the asynchronous call by reference node which forces you to keep the connector pane the same and then use other methods to communicate to my dynamically called SubVIs)
(blog)
(4,216 Views)
Sam
Thanks for the quick response. I do have a reference to the subVI  but I can't find VI.Panel.Controlls[] . I'm new to LabView so if you could point me in the right direction that would be a help.
Larry
(4,202 Views)
Accepted by topic author lsmith5161
(4,191 Views)
First you get the reference to the front panel of the VI, then you get the Controls[] property:
(blog)
(4,189 Views)
Nevermind, I found it thanks for the help!
(4,187 Views)
The credit goes to Sam, I just showed the property nodes that he described!
(4,162 Views)
