How to read RGB from Tiff Image
I used IMAQ Image To Array VI to read RGB value from a tiff image, but it can't read. What IMAQ should I use to read the RGB values?
(3,329 Views)
please check this: I dnt think there is any built in function available to read tiff iamges
read tiff images
(3,196 Views)
Hi Jason,
IMAQ ImageToArray VI can only read grayscale images. For color images (including TIFF type), you can use IMAQ ColorImageToArray VI. Below is an example that works, and the screenshot of the resulting front panel is attached.
You can check the supported image type for evey IMAQ VI by clicking the detailed Help and check the icons above the VI image as seen below (red highlight), or check the compiled summary ("Supported Image Types").
Hope this helps.
Yodha
NI Singapore
(3,164 Views)
There is a post on IMAQ Bayer To RGB,hope it can help you decode image color information.
http://forums.ni.com/t5/Machine-Vision/How-to-use-IMAQ-Bayer-To-RGB/td-p/2454656
(3,097 Views)
