03-18-2010 03:51 AM
03-18-2010 04:05 AM
03-18-2010 06:00 AM - edited 03-18-2010 06:04 AM
rolfk wrote:
ADO/DAO used to be all that was necessary to access mdb files. So using the database connectivity toolkit should simply work. You simply setup a DSN or maybe UDN pointing to that file and use that when opening a connection to the database with the database toolkit functions.
I believe that the correct term is UDL (Universal Data Link). I only point it out because you won't find any anything googling 'udn'.
See this knowledgebase entry regarding creating a UDL file.
I've always used UDL files; I wrote my own ADO based libarary over 10 years ago.
After 7 ADO updates and three OS upgrades (NT, 2000, XP) it still works fine. Most of my ATEs don't have M-Office installed, only OpenOffice.
You can also use ADO to read and write MS-Excel files with the correct ADO options...
A UDL file contains ASCII text. There is a web site full of information about the options for various databases and file types. See www.connectionstrings.com
03-18-2010 09:01 AM
03-18-2010 09:31 AM
Actually, while a UDL file is a text file, if you double click on it in WinXP or later you'll get a window popup similar to this:
You can use this tool to set specific options for the DB access (for example, password-only access). And UDL files work regardless of whether you use the LV toolkit. I've used UDL files with VB and scripts in other programs (like JMP or MATLAB).
03-18-2010 11:04 AM
So do DSNs and direct connection strings.
