How to read any voltage (0-10v) with NI 9421
Hi I am a biginner in cRIO. Playing with cRIO-9012, NI9421.There is an example program in Labview named " NI 94xx Input - Getting Started - Scan Mode". its a basic program just to show the LED status when there is something in DIO1. I implimented the program by changing the target chasis. To see how it works, I used a calibrator to send some voltages to NI9421. The LED is actually turned on at 8v. My question is how can I turned it on even in lower voltages like 2v, 3v, 5v. Somebody please help me out which settings I need to change.?  I attach the screen shots of the program and the example file from labview.
(3,644 Views)
You're going to need an analog input module and not just the digital module. Are you familiar with the differences between the two?
(3,636 Views)
Thanks and sorry if I explained that wrong. The NI example that I am using is about Digital input. Any NI 94xx series can be used. I tried to input a counter/pulse but it doesnt read that. What I am looking for is to read a triggering pulse of any voltage level. Right now it is only reading when the voltage lavel is up to 8 v.
(3,616 Views)
Accepted by topic author Uzzal_us
If you look at the data sheet for the 9421, it is a 24V logic digital input module.  It states that an off state is 5V or less and an on state is 11-30V.  Anything in between should be considered unstable.
You can't just pick the logic level for the input module.
(3,606 Views)
Some how I thought that its 0-10v. I should have read the data sheet before using that.Thank you very much.
(3,590 Views)
