If I remember correctly, there is a DOS command that allows you to redirect the output to a file. You could put this command in your batch file.
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
