convert a string array to a 2-d array
I am trying to convert a string array from a shift register to a 2-d array so that I can save the array using write to speadsheet.vi.
Thanks for your help!!
(3,386 Views)
Use 2 "for" cycles with autoindexing so you will get in inner cycle only one element of string array. Use one of StringToNumber vi's and you will get 2-d array of numbers.
(3,386 Views)
Thank you for your reponse! I am still having trouble wiring up the for loops (one with in the other). I am not sure how to leads the 2-d sting into the loops.
(3,386 Views)
Hi Gorelick.
Everything is much easier. Just use string to number vi's where strin input will your 2-d string array. You will get 2-d numeric array.
P.S. For leading 2-d string into array connect its wire to "For" left edge. You will see small point on the edge, click on with right button and select "enable indexing".
(3,386 Views)
thanks a lot, I will give it a try!!
(3,386 Views)
