How to read data from a zipped MS Access file?
(3,263 Views)
First you are going to have to unzip the file and put it somewhere.  There are some VI's that work with zip files under the file I/O palette.
Once you have that, you will need to communicate with it.  Search the forums for numerous examples on how to communicate with an Access file.
(3,259 Views)
Hello RPJ,
There is a VI located in File I/O»Zip»Unzip that will unzip a folder.  Use this and then you could either use ActiveX to communicate to Access or the Database Connectivity Toolkit.
Jon S.
LabVIEW NXG Product Owner
(3,224 Views)
Thank you.
Do I need to use "Close Zip File.vi" after that?
(3,220 Views)
I do not have the Database Connectivity Toolkit.
Would you happen to have (or point me to) an example?
Thanks.
(3,219 Views)
RPJ,
You do not need to use the Close Zip File.vi when you unzip a folder.  This VI is used when you are creating a zip folder.
As for examples, I found a couple of ActiveX based MS Access examples.  These programs look to be pretty basic.  For more in depth example I would search Microsoft Developers Network
http://zone.ni.com/devzone/cda/epd/p/id/2188
http://zone.ni.com/devzone/cda/epd/p/id/1694
Jon S.
(3,170 Views)
Using ActiveX and Access is not a very optimum solution, imho. If you don't want to buy the Database Connectivity Toolkit, try LabSQL. You will also find numerous posts on using ADO.
(3,162 Views)
