04-02-2009 04:29 PM
04-02-2009 04:38 PM
First you are going to have to unzip the file and put it somewhere. There are some VI's that work with zip files under the file I/O palette.
Once you have that, you will need to communicate with it. Search the forums for numerous examples on how to communicate with an Access file.
04-03-2009 04:21 PM
Hello RPJ,
There is a VI located in File I/O»Zip»Unzip that will unzip a folder. Use this and then you could either use ActiveX to communicate to Access or the Database Connectivity Toolkit.
04-03-2009 04:23 PM
Thank you.
Do I need to use "Close Zip File.vi" after that?
04-03-2009 04:24 PM
I do not have the Database Connectivity Toolkit.
Would you happen to have (or point me to) an example?
Thanks.
04-06-2009 10:39 AM
RPJ,
You do not need to use the Close Zip File.vi when you unzip a folder. This VI is used when you are creating a zip folder.
As for examples, I found a couple of ActiveX based MS Access examples. These programs look to be pretty basic. For more in depth example I would search Microsoft Developers Network
http://zone.ni.com/devzone/cda/epd/p/id/2188
http://zone.ni.com/devzone/cda/epd/p/id/1694
04-06-2009 11:53 AM
